850 to 940 seat swap
Old Aug 4, 2015 | 03:47 PM
Moetheshmoe's Avatar
Default 850 to 940 seat swap
Does anyone know if seats from an 850 will fit a 1993 940 Turbo?
Thanks
Old Aug 4, 2015 | 04:07 PM
no, pretty sure they won't. I measured them when I had an 850, just for laughs. 240's won't interchange with 7/9's either. you need the seats from a 740 or 940/960 if you want it to bolt in, and note that 740s have a different cushion design with a longer thigh support. also the wiring for seat heaters and power seats can vary by year, but its not that hard to swap it around. I also had to swap the seat belt fasteners when I did a seat swap (I took the old seats out of my 92 740 and put them in a 91 940SE (really a 960), and took some newer 960 seats and put them in my 740...
Old Aug 4, 2015 | 07:15 PM
Yeah, I was afraid so. Sounds like you've played "musical seats" and tried all the combos. Thanks
Old Aug 4, 2015 | 07:33 PM
On the 240 and 850, I just measured the rail centers and bolt distances, I didn't bother to remove seats and try them.
Old Aug 4, 2015 | 07:53 PM
My main concern is wiring. I'd like it to be a plug in match. And I'm hoping to switch the leather with cloth. I don't know if I can achieve both of those. I hope the cloth seats from the same year had all the features of the leather ones.
Old Aug 4, 2015 | 07:57 PM
cloth was pretty rare on US model 940s most every one I've seen has been leather. do you have a power or manual driver seat? do you have seat heaters? those were all options, and/or bundled with different trim levels (GLE vs GL, etc).
the three years I swapped seats between all had different heater and power seat connectors (well, ok, my 92 740T didn't have power seats at all, so I had to run power to the drivers seat).
Old Aug 4, 2015 | 09:35 PM
What I've noticed is sunroofs and leather were one package. They always went together, except on Canadian cars. And all Turbo's had sunroofs. So I need a non Turbo, which is usually a GL, but I don't know if they had power and heat?
Old Aug 4, 2015 | 10:03 PM
you /could/ put cloth custom fit covers over formerly leather seats... the custom fit covers made by various outfits generally fit quite snugly after removing the original skins, and if properly installed with 'hog rings' around the bottoms, are quite snug and reasonable.
Old Aug 4, 2015 | 10:09 PM
That is plan B if I can't find what I want. Any recommended suppliers? There's quite a few out there and they ALL say theirs is the best.
Old Aug 5, 2015 | 12:00 AM
lev's Avatar
lev
Both 940 turbos and NA can be with cloth seats or leather. Power seats or not. Sunroof or not. Fog lights or not. I have a '945T with no roof, cloth manual seats.
The GL designation was dropped after the '92 MY.
Cold weather package had heated seats, outside temp gauge, locking dif.
And, no, you cannot put 850 seats in a 940 without major cost prohibitive mods!
Old Aug 5, 2015 | 02:10 AM
92Sedan's Avatar
Even window switches wont swap between the two, I'd hunt down a late model 960 and get interior bits from that.
Old Aug 5, 2015 | 10:16 PM
Have you ever seen cloth seats with power and heat?
Old Aug 7, 2015 | 04:07 PM
lev's Avatar
lev
yes i have.
Old Aug 8, 2015 | 08:51 AM
yes i have.
Good to know. I'd hate to keep looking for something that doesn't exist.
Old Aug 8, 2015 | 10:25 AM
lev's Avatar
lev
doesn't mean you'll find one in good condition to be useful. if you have your heart set on this you can get a power seat and put the cloth Volvo seat cushion and back cover on--i've done this many times and it's not hard...
Old Aug 8, 2015 | 11:26 PM
I remember Pierce suggesting(if I stay with leather) to go to a junk yard and find a passenger seat in good condition and switch the cushions(which is the only ripped part). Is there a diy tutorial on replacing seat cushions?
Old Aug 9, 2015 | 12:07 AM
  #17
its pretty easy to figure out. 4 bolts and a couple connectors, and the whole seat comes out of the car.
the seat back, you peel the skin off after removing the headrest and any clips or hog rings at the bottom of the back. IIRC, the seat cushion, you pull some rods out the side and the skin comes off. the passenger seat back cover has the hole for the lumbar support on the wrong side, so you have to cut a hole which can be hemmed with waxed upholstery thread. when you have the covers off, repair any broken springs and wires in the base, and if the foam is broken down, you can swap it too.
Old Aug 9, 2015 | 08:54 AM
  #18
Sounds easy. If I can find the right color I'll give it a shot. One other question, the passenger seat is ok, no rips or cracks but the color is gone in some areas. I've seen online stores that sell leather "rebuild kits" with filler and dye. Ever tried that?
Old Aug 9, 2015 | 12:10 PM
  #19
only thing I've done is leatherique restoration, worked great on mercedes, OK on volvo leather. I haven't tried dyeing any leather, or filling.
Old Aug 9, 2015 | 08:45 PM
  #20
Can you buy new Volvo cloth skins or did you get them from a donor car?
