86 740 Turbo wagon
Old Dec 18, 2006 | 01:25 AM
txturbo's Avatar
Default 86 740 Turbo wagon
Hey guys......new guy here. Just acquired a non-running Volvo for a weekend project. Probably gonna have some questions real soon and I hope someone can help me out. First thing I have to do is get some injectors to replace the ones the previous owner removed and lost and reinstall the distributor. Car wouldn't start and they figured out that it was an electrical problem but have no idea why they took the injectors out.
Dan
Old Dec 18, 2006 | 01:32 AM
Default RE: 86 740 Turbo wagon
Welcome
Old Dec 18, 2006 | 09:12 AM
txturbo's Avatar
Thanks....hopefully I will have time today after work to dive into this thing and get an inventory of parts needed to make this motor complete again. Then I can start troubleshooting.
Old Dec 18, 2006 | 09:21 PM
txturbo's Avatar
Ok......got to take a look and do some inventory on the new acquisition. Need 4 injectors for sure. Distributor seems to be all there, but I noticed the pickup coil is loose in the distributor housing. Looks like 2 pins sticking through holes in the housing, but nothing to hold it stationary. One pin fits fairly snug but the other housing hole is about twice as big as the pin on the pickup coil. Is something missing? Also noticed a missing component on the front side of the passenger side strut tower. All thats there is an unconnected harness connector. Anyone know what goes there?
Old Dec 18, 2006 | 11:08 PM
Any way you can post a pic of the empty plug?
The plastic piece usually breaks in the dist. Housing the wires.
It is replacable. That will also stop it from running.
Old Dec 19, 2006 | 12:27 AM
txturbo's Avatar
I figured out the large connector. It goes on top of the air box.
Old Dec 19, 2006 | 12:39 AM
Oh ok the Mass Flow sensor plug.
Old Dec 19, 2006 | 09:12 AM
txturbo's Avatar
So you're saying the pickup coil in the distributor has a plastic piece thats broken off? If so, does that mean I'll have to buy a new pickup coil or is there a seperate peice thats broken?
Old Dec 19, 2006 | 09:28 PM
txturbo's Avatar
Looks like the distributor housing is broken. The pickup coil slips over two pins and it looks like one or both pins are broken off.
Old Dec 20, 2006 | 01:06 AM
The plastic plug where the harness connects is what I am talking about.
The black piece that the plug connects to alot of times breaks and shorts out on the Dist.
Old Dec 29, 2006 | 03:04 PM
txturbo's Avatar
Update......got my distributor reassembled and installed. Got my injectors off ebay yesterday, new o-rings and installed. Now I need help with the coil wires. I have 4 wires. One big fat grey wire(looks like the power wire), one white wire, and two blue wires. Which ones go to the + side?
Ok....I figured out the blue one was power and the white goes on the - side. I have fuel at the pressure regulater, spark, fresh gas, but it sounds like its trying to start but not quite. When I stop cranking though I get a backfire on the exhaust side. Any suggestions?
Old Dec 30, 2006 | 12:09 AM
Firing order off?
Old Dec 30, 2006 | 09:55 AM
txturbo's Avatar
I checked that. I'm assuming Volvo numbers from front to rear though. Is that correct?
Old Dec 30, 2006 | 12:33 PM
When you stand in front of the car and look on the CAP the order is 4-3-1-2
#1 cylinder is always by the timing belt and then work backwords.
Old Dec 30, 2006 | 02:04 PM
txturbo's Avatar
Ok.....I had it right then. Did some more checking. Pulled the timing cover and noticed the cam gear marks didn't line up with the bottom pulley on the 0 mark. Lined everything back up and its still not right. Looks like my outer ring on the balancer has slipped. The belt looks new and the previous owner didn't say anything about installing a new belt. Looks like they have the timing wrong. Anybody have a spare balancer?
Old Dec 30, 2006 | 04:42 PM
You can set the timing properly without having a new balancer.
Pull it down like you are doing a timing belt and use the marks on the engine.
Old Dec 30, 2006 | 08:51 PM
  #17
txturbo's Avatar
Tried to set it by sticking a screwdrive in the number sparkplug hole and turning the crank until I found TDC. I must not have got it close enough. Still wouldn't run. One thing I noticed though, the rotor is closer to the #3 tower than the #1 when the cam timing marks are lined up. Is that normal or has something else slipped?
Old Dec 30, 2006 | 09:21 PM
  #18
I would tear it all apart and recheck all marks.
Old Dec 30, 2006 | 11:36 PM
  #19
txturbo's Avatar
Thats the plan for tomorrow If I can get the bolt loose on the crank pulley.
Old Dec 31, 2006 | 12:55 PM
  #20
txturbo's Avatar
I pulled the crank pulley this morning and the lower timing cover. Rolled the crank until the marks lined up, but didn't expect to see what I saw. All marks lined up. I just guessed at TDC and the intermediate pulley location yesterday. One thing still doesn't look right though. The rotor points to #3 plug wire tower instead of #1. Am I missing something? I know that the rotor won't line up with #1 exactly at TDC, but is it suppose to be that far away? Rotor only goes on one way, distributor only goes in one way, with those white marks lined up the bolts line up with the marks the washers left on the housing. I tried taking out the distributor hold down bolts yesterday to see if I rotated the distributor further if it would run, no luck.
[IMG]local://upfiles/8151/0A17903123FC43BEB790D6C9D6A6E2C6.jpg[/IMG]
