87 240DL won't start...HELP!
Old Sep 21, 2008 | 08:00 PM
perryc516's Avatar
Default 87 240DL won't start...HELP!
Hello to everyone, I'm perry and I'm a newbie. I have this 87 240DL wgon that I've been driving for two years now. I was warming up the engine one morning and the enging died. It will crank but will mot go. I thought it was the fuel pump so I took the FP out and tested it...it was working. I checked all my fuses as well. I also checked the voltage of the wires going to the FP. I am only getting .63 volts when I crank the engine. I also replaced the fuel pump relay...still no luck. I removed the distributor and check for ignition and fuel injector response, I am getting ignition spark but I am not getting any sound or movement from the injectors when I turn the distributor manually. What coul be the problem? Thanks in advance.
Old Sep 21, 2008 | 08:12 PM
Default RE: 87 240DL won't start...HELP!
The pickup in the dist might be bad.
Old Sep 21, 2008 | 11:18 PM
perryc516's Avatar
Ok, so even if I get spark while rotating the distributor by hand, if the trigger is bad, i will not get any signal going to the injectors? And if I don't have any signal or voltage going to the injectors, does that have something to do with the low voltage going to the fuel pump?
Old Sep 22, 2008 | 01:32 PM
bubba240's Avatar
Clean the 20A fuse on the fender near the coil and measure the voltage on the red wire at the fuel pump relay. You tried a known good relay?
Old Sep 22, 2008 | 07:52 PM
perryc516's Avatar
I think I've tried some good relays...well, to be honest, I'm not sure. I have seven fuel pumps that came from the yard, one or two of them should be good. I am getting 12 volts from the big red wire where the pump relay attaches. Today's update: I tried my ECU on another car and it works. The same thing as the distributor. I tried it on a running 240 and when I turn the distributor manually, I am simultaneously getting spark and injector pulse.
Old Sep 22, 2008 | 09:21 PM
perryc516's Avatar
ORIGINAL: bubba240
Clean the 20A fuse on the fender near the coil and measure the voltage on the red wire at the fuel pump relay. You tried a know good relay?
I checked the voltage where you plug in the FP relay. The small red wire, I get 12 volts but on the big red wire, I'm only getting 9 volts. What could be the problem?
Old Sep 22, 2008 | 11:03 PM
fredbyte's Avatar
If this is a B230F engine, then go to www.stepbystepvolvo.com and download the diagnostic guide to 740 no-starts.
Old Sep 23, 2008 | 09:32 AM
bubba240's Avatar
The connection at the + battery terminal, the black junction box on the fender where all the red wires meet, corrosion inside the 20A fuse holder or the 20A fuse by the coil.
Old Sep 23, 2008 | 10:19 PM
perryc516's Avatar
ORIGINAL: bubba240
Did that...same...no luck.
Old Sep 23, 2008 | 10:20 PM
perryc516's Avatar
ORIGINAL: fredbyte
Mine is a 240DL, is it the same as the 740?
Old Sep 27, 2008 | 07:19 PM
perryc516's Avatar
[quote]ORIGINAL: bubba240
Tested all the fuel pump relays I have and found that I have seven out of seven relays. I am kinda confused , the diagram says E is the main relay. Which one is the fuel pump relay? I am only getting 9 volts when I turn the key on. Does the Air Mass sensor affrect or cause this problem. working relays.
240driver
Jul 14, 2015 09:27 AM
akpasta
Jan 31, 2013 12:30 PM
aletaaa
Jun 30, 2012 08:29 PM
dustintinsley
Aug 6, 2010 01:13 AM
Patdon10
Jul 22, 2007 10:30 AM
