87 244 very strange turn signal issues
Old Feb 22, 2018 | 08:41 PM
cdubb's Avatar
Default 87 244 very strange turn signal issues
So my friend just bought a pretty nice 244 and we are tracking some light issues. All the lights worked besides the passenger side marker light, we checked bulbs and wiring and figured it was something with the housing. He got a used housing today and the marker light works but now the turn signal does not, the running light flashes fast and the turn signal stays dark. The passenger rear works and flashes fast, driver sides both work and flash normally, hazard lights work and blink normally except on the passenger side which does nothing at all. We checked grounds, fuses, wires and tried three different corner light assembles and had the same problem with all.
Where do we go now?
Old Aug 8, 2020 | 02:55 PM
Stitch's Avatar
Where do we go now?
Hello all!
Was there ever a solution for this?!
I stumbled across this post as I have encountered the exact same issue:
passenger side front lower turn bulb
is dead and the top running light bulb flashes fast (as does the rear).
Both front and rear drivers side work fine. Hazards work fine.
just checked voltages at the steering column switch and that works.
bulb housings all tested ok. Cleaned ground at the fender those are good.
swapped entire turn signal housing and wiring to harness connector, same issue.
my thought is the connector harness side at the fender failed maybe?
I’ll test voltages at the connector in a bit...
Old Aug 8, 2020 | 03:30 PM
Stitch's Avatar
Default Edit
Oh one thing, in rereading the original post that seems different in my situation:
hazards work and blink normal
rear lights all hazard blink normal.
front driver side blinks normal
front passenger side blinks BUT not
on lower turn bulb, it blinks the top bulb.
any thoughts, anyone?
Old Aug 8, 2020 | 04:48 PM
Stitch's Avatar
Default Edit 2
Heh, so traced it to the ground at the RF fender. I had pulled them and scoured and tested continuity, but the failure was right above the ground lug
and failed again once wire was kinked back down in engine bay.
spliced a retro fit, cleaned up that ground connection once more and all is well.
centenj
Mar 17, 2020 12:48 PM
suener
Oct 17, 2019 03:47 PM
Moetheshmoe
Nov 27, 2017 03:38 PM
Mikenem
1998-2000 model year V70
Dec 29, 2016 06:19 AM
Patdon10
Sep 14, 2007 06:52 AM
