87' 740GLE Popping Noise taking off from first gear
Old Dec 29, 2014 | 05:13 PM
djbrndo850's Avatar
Default 87' 740GLE Popping Noise taking off from first gear
I have a weird popping noise and I can feel it when taking off from first gear. It also happens at second but less noticeable. Any ideas on what it could be. It happens sometimes when I accelerate in the other gears. Should I just get rid of it and save myself the pain?
Old Dec 30, 2014 | 11:54 AM
Blue91SL's Avatar
U-Joints... Rear diff, differential bushings... Could be a lot of things. When is the last time the fluid in the rear end was changed?
Old Dec 30, 2014 | 02:20 PM
djbrndo850's Avatar
Honestly probably never as far as I know. It was given to my by my uncle last year for free so I don't think much maintenance has been done in a while. I'm thinking it's the rear differential since whenever I go over a small uneven hump or accelerate the noise starts. If I push the clutch in the noise stops
Old Dec 30, 2014 | 03:59 PM
its probably a very good idea to get this car up on a lift and inspect the spring seats and such for corrosion damage. most suspension noises that /I've/ heard have been more like clunks and rumbles, and not popping sounds.
another thing to check is the driveshaft center bearing.
Old Dec 31, 2014 | 07:14 AM
djbrndo850's Avatar
Thanks for the insight. I guess to me it sounds like popping but it could also be heard as a small clunk. Taking it in soon as possible. Hopefully it wont wreck my wallet.
Phil 850
Nov 16, 2013 11:33 PM
78vovlo244
Aug 20, 2008 12:25 AM
Inlinesix
May 13, 2008 05:56 AM
Lab_Rodent
Nov 3, 2007 01:12 AM
