88 240 fuel issue
Old Jul 1, 2011 | 06:58 PM
88240's Avatar
Default 88 240 fuel issue
I have an 88 240 and about 2 weeks ago it started to sputter and stalled. I had about a half tank of gas and put the hood to see if there was any visible vacuum hoses off. About a half an hour passed and she started running again. The same thing happened again today and after sitting about 1/2 hours she ran again. I don't know if the fuel pump is overheating if that is even possible. Has anyone experienced this before? I also live in Tucson where it's been 100 degrees lately. Any assistance would be greatly appreciated.
Thanks,
Chris
Old Jul 1, 2011 | 07:47 PM
Burn Stains's Avatar
How many miles are on it? Is it an original in-tank pump?
Old Jul 2, 2011 | 09:15 AM
88240's Avatar
There are 248000 miles on it and I don't know if it's the orginal pump in the tank. I purchased a fuel filter yesterday which I will change today and I'm prepared to do both the external and internal fuel pumps.
Old Jul 2, 2011 | 05:16 PM
Your in-tank pump might be on its last limb if it is original. As for the main pump, those things either work, or they don't and are quite resilient, I would not bother changing that right now as long as it is not making any loud buzzing noises.
Old Jul 3, 2011 | 02:36 PM
88240's Avatar
Thanks for the info. I went to change the fuel filter yesterday and that turned into a huge debacle. Now under pressure fuel spurts out on the 18 mm side. I have the copper washers installed correctly, but it doesn't want to seal properly. Have you ever heard of that?
Old Jul 3, 2011 | 09:07 PM
Did you replace the fuel line between the pump and filter?
Old Jul 4, 2011 | 06:22 AM
ed7's Avatar
ed7
The solder connections on the relay are falling apart; resolder the connections or replace the relay.
Ed
Old Jul 4, 2011 | 10:33 AM
88240's Avatar
No I didn't change the fuel line between pump and filter. I will check the relay for the original issue. Thanks
240Matt
Apr 21, 2013 06:55 AM
AnEskimo
May 15, 2011 12:32 AM
Joshbaldwin
Jan 12, 2009 02:06 PM
orcutd
Sep 27, 2008 08:13 PM
abstract
Sep 25, 2007 08:58 PM
