88 240 Fueling Help
Old Oct 11, 2004 | 02:28 PM
Boggus's Avatar
Default 88 240 Fueling Help
Pump works but I am getting no gas to the motor. I can crawl under the car, have some else crank it for me while I tap on the accumulator? and it will begin to start.
Wondering if that is an accumulator or filter under there. 2 lines come from the tank, go into the pump out of the pump and looks like a pass through on the accumulator.
Any help or insight would be appreciated.
Old Oct 11, 2004 | 02:44 PM
Default RE: 88 240 Fueling Help
Look under the hood on the firewall if there is not a filter on teh drivers side on the firewall then that is a filter bye the pump.I do believe that your car has it underneath bye the fuel pump.It should be fine once you put a new filter on.When you buy a new filter make sure they give you the 4 copper washers 2 on each side.Good luck
mojo
Jan 6, 2013 06:40 PM
Dr. J
Jun 5, 2011 10:54 PM
uenvyboykin
Dec 29, 2008 02:47 AM
markjenross
Nov 7, 2007 08:02 PM
denbass
Oct 23, 2007 03:45 PM
