88 740 brake lights
Old Sep 7, 2006 | 02:22 AM
TedH's Avatar
Default 88 740 brake lights
My brake lights stopped working...the brake light switch on the pedal is getting voltage and changing when the pedal is pressed. there is no voltage at the brake lights though. i traced the wire using a diagram and an hour later came up with nothing. the break light circuit is a part of the abs circuit, the wire goes from the break switch to no mans land under the dash i also noticed that the circuit goes through the bulb failure sensor by the relays behind the ash tray but if that was the problem i would think that more than just the break lights woudl not work. if any one has any suggestions please reply.
Old Sep 7, 2006 | 08:45 PM
Default RE: 88 740 brake lights
Remove and open the Bulb failure relay and inspect.
I will bet your problem is the relay.
88740gle
Nov 13, 2015 08:13 AM
aznyaz
Jan 9, 2015 02:38 PM
Scott V
2001-2013 model year V70
Jul 21, 2013 02:28 PM
Mellott
Jun 13, 2011 11:41 PM
chrystald423
Mar 27, 2010 08:05 AM
