244DL Starting problem
Old Sep 7, 2006 | 08:49 PM
haightc's Avatar
Default 244DL Starting problem
I am trying to fix my GFs 1982 244DL, I beliebe it's a b23a engine. I don't really have much experience working with carburated cars. Car failed to start... got it to start again... started chugging... then failed to start anymore.
Here is what I have done. I have relaced the starter (it had failed earlier), also replace the distrubutor cap and ign rotor. Then whne it stop running again I replaced the fuel filter on the idea of a fuel delivery problem. I noticed before it completely failed the second pump was running really loud. As I read this is and indication that the in tank fuel pump has failed. Since I replaced the fuel filter there feels like there is lots of pressure in the line between the carb. In the air intake there is excess fuel. So I would assume the carb is getting fuel to it. Oh, and I check the spark and it's fine.
So, what should be my next step?
predmore06
Jan 23, 2011 11:35 PM
predmore06
Jan 22, 2011 05:37 PM
JaySVX
Jun 22, 2007 08:42 AM
drfrankenstein
Mar 25, 2005 09:57 AM
mctwin2kman
Oct 11, 2003 04:01 PM
