'88 740 GLE no spark
Old Mar 31, 2024 | 08:19 PM
oddballjay740's Avatar
Post '88 740 GLE no spark
I have a 1988 Volvo 740 GLE non-turbo with bosch ignition system. I bought it with a fuel issue, but quickly handled that and got both fuel pumps working and flowing properly with good pressure. Thats when i realized that fuel was not the only issue... i cannot get spark!
i admit i jumped the gun, and im guilty of throwing parts at it. i cant be the only one anxious to bring a volvo back from the dead!
symptoms:
-No spark coming from coil upon cranking
-no spark coming from distributor cables
-tach not moving/jumping upon crank
-no spark coming from the 'ignition coil to distributor' cable
im getting 11.5v at the coil lead wire with ignition on, then when i crank, it drops to 10v then quickly back to 11.9.
im getting 11.9v from coil lead wire while it cranks but still not any sign of spark when i try to ground out that ignition cable wire to the frame/body.
im used to working on older 70's model carb engines so i did what id normal do and replaced all ignition components.
parts replaced:
-coil
-spark plug wires
-spark plugs
-distributor
-cap
-rotor
-ignition control module (behind the headlight)
-ignition mini fuse
im not getting a timing pulse from my ignition control module harness. just getting a constant 12v with the key/ignition on.
my hall sensor connector wasnt in the best shape but i did my best to re splice it and repair it.
before i buy an ignition control unit that goes under the dash i want advice. anything helps at this point.
thanks
TalonNorthern
Oct 17, 2023 09:16 AM
Makozi
Dec 11, 2022 02:57 PM
Thim
Aug 20, 2019 03:07 PM
Mike244DL
Nov 7, 2018 06:25 PM
Theshaggystump
Aug 26, 2018 10:40 PM
