'88 740 no one seems to be able to fix it!
Old Jul 4, 2008 | 09:07 AM
camperstron's Avatar
Default '88 740 no one seems to be able to fix it!
Hi!
I have an 88 740. 3 weeks ago it just cut out, totally died while my husband was driving home from work.
We got it towed to a garage and a faulty coil pack was diagnosed. The car was sparking - but the engine wouldn't turn over.
The coil pack was replaced - the car still wouldn't work.
New HT leads were fitted - still nothing.
A new distributor was fitted - the car then started but the engine wasn't running properly.
The engine timing was looked at (timing belt was adjusted) and the car ran well....
However, it now sometimes won't start.
The guy at the garage is pretty stumped and is talking about having it scrapped. I've asked him to have a look at the fuel pump relay. Is there anything else that he should be looking for or should I just cut my losses with my lovely 740?
Thanks.
Old Jul 4, 2008 | 09:13 AM
Default RE: '88 740 no one seems to be able to fix it!
Maybe fuel pump is going bad.
There could be a few other things like the computer.
Are they a Volvo specialist?
Old Jul 7, 2008 | 04:43 AM
wojeepster's Avatar
Get another mechanic. He is obviously just replacing things without a clue..... fuel pump relay is a possibility also if tank is half full or less when problem occurs suspect in tank pre pump, main pump is also a possibility.
Old Jul 15, 2008 | 10:06 AM
fredbyte's Avatar
Go to www.stepbystepvolvo.com. It has a nice diagnosis no-start troubleshooting guide for 740/940s.
jimmy5
Mar 4, 2015 12:15 AM
mhop3420
2001-2013 model year XC70
Jan 6, 2015 06:25 PM
123popeye123
May 1, 2013 06:54 AM
curiousman
Mar 4, 2010 10:10 AM
rogereloco
Aug 27, 2008 12:05 AM
