'89 740 Blower motor problem
Old Feb 11, 2008 | 07:05 PM
hotrodolds's Avatar
Default '89 740 Blower motor problem
The blower motor in my 1989 740 Wagon quit on me. I have been going nuts trying to find one, and so far, in the aftermarket, I've found many one wire motors. I have a two wire motor. I just got one from a '90 that was a two wire, but the connector is wrong. Quite frankly, this is beyond annoying. It is a problem that shouldn't exist. But, apparently, nobody makes a two wire motor for this car.
It is a 740GL with air, and without automatic climate control. Does anybody have any ideas? Thank you in advance.
Old Feb 11, 2008 | 07:38 PM
Beardog's Avatar
Default RE: '89 740 Blower motor problem
I have the same vehicle. I purchased one off of partsamerica.com. Make sure you get one with lots of fan blades. The one I purchased had less blades and doesn't blow as hard now, but I'm sure it spins around the smae rpms.
Old Feb 11, 2008 | 08:22 PM
hotrodolds's Avatar
None of those are right, either. I've been through the Siemens part numbers at AutoZone, and all the others are either one wire, or that connector is wrong, still.
Old Feb 12, 2008 | 09:37 AM
colgate41's Avatar
I believe i had the same problem with my 91' 740. Bolwer motor went due to a bad water leak, so i ordered a used one from "you need a part", basicaly as junk yard for america, and i needed a blower motor with 2 connectors but the one ei got dident match up right. But i was able to just make it work, i cut off a peice and jammed it on cause i was so frustrated and its been working for over a year now. Basicaly what im saying is, if you get a blower motor with somewhat the right conections, you can make it fit.
Old Feb 12, 2008 | 03:21 PM
hotrodolds's Avatar
Yeah, that's what I'm going to try to do with this one I've got now. I've wasted too much time and money freezing. We've had -35* actual temps a couple times, and that's just miserable. I think I can get this to go together with a little solder.
Thanks for the help...just wanted to make sure I wasn't missing something obvious.
StevenBishop
Jan 15, 2015 09:46 AM
SmrkngRvng
Feb 26, 2013 03:57 PM
Koriflame
Sep 8, 2011 10:08 AM
brmicbman
Feb 9, 2011 01:32 AM
Collkid
Nov 10, 2008 09:40 AM
