89 Volvo 740 control arm bushing replacement question
Old Sep 12, 2015 | 11:00 AM
volvo745newbie's Avatar
Default 89 Volvo 740 control arm bushing replacement question
Hello All, today i'm attempting to replace the outer control rod bushings on my 740, the ones that are cone shaped. i was able to loosen the bolt that compresses the 2 cone pieces with no problem. My problem is the bolt that attaches the radius rod to the subframe. The cap of this bolt looks like a large Torx bit, it is male and not female. On the other side is a normal looking nut. My questions are as follows;
1 what is the size of the torx "socket"?
2 is the nut welded to the bracket.
3 can i use a impact socket and drive to remove the nut "which is easier to access than the inbord side of the bracket" and not worry about that weird torx thing?
Thanks Logan
Old Sep 13, 2015 | 01:40 PM
yeah, that nut comes off.
Old Sep 14, 2015 | 05:12 PM
Thanks Pierce! I got it finished last night. I knew i had to use a breaker bar with a cheater to get it loose but i was afraid if the nut was welded on i'd cause some major damage. I found that a 17mm 12 point socket had enough bite on that torx thing to allow the nut to be fully removed from the bolt. it's always the small stuff that seems complicate any proceedure. Thanks again!
Old Sep 14, 2015 | 05:44 PM
I think those 'inverse torx' bolts are called 'triple-square' or XZN. they come as both bits (for innie cap bolts, like torx but a different set of angles and NOT COMPATIBLE) and sockets (for bolts like you ran into here).
vrktring
Nov 27, 2011 09:58 AM
vrktring
Nov 21, 2011 09:24 PM
phoffman
Sep 2, 2007 03:07 PM
dpm2340
Nov 26, 2006 01:17 PM
dpm2340
Nov 26, 2006 12:04 PM
