90,240 fuel pump ghosts?
Old Jan 12, 2009 | 02:17 PM
Joshbaldwin's Avatar
Default 90,240 fuel pump ghosts?
I have to turn my key over many times, or sometimes once to get my fuel pump to prime the system. I have pulle it off and tested it to work fine. When I put it back on it does the same thing. I have all new fuses in the box. I also didn't mention that it is the rail pump. I haven't gone into the tank yet. The car has always made the fuel pump prime noise for 8 yrs. Now I have to play the ignition key off and on till I hear the buzz. Then I have no problems driving. When I shut it off, I might have to do the same thing again. Is it bad wiring? Should I hot wire it with a switch? Any impute would be appreciated. Thank-you volvo nation.
Old Jan 12, 2009 | 04:05 PM
bubba240's Avatar
Default RE: 90,240 fuel pump ghosts?
I would replace the fuel pump relay - its white, on the firewall above the passenger's feet.
Old Jan 12, 2009 | 06:46 PM
bubba240's Avatar
You have to fold back the black carpet that is clipped on below the glove compartment to see it. (thats where it is on my 86 - maybe it moved by 92???)
[IMG]local://upfiles/15703/84BBC5ED92F34A2592546A528A7A5CE9.jpg[/IMG]
Old Jan 13, 2009 | 12:06 PM
Yes, now I know what I'm looking for. It's not on the passenger side so I'll keep looking. Thank you for the help
spidersilva
Aug 17, 2011 07:23 PM
montysano
Sep 9, 2008 11:52 AM
lister99
Apr 22, 2008 10:53 PM
paulfr
Aug 31, 2007 08:00 AM
