90 Volvo 240 231 fault Code
Old Aug 1, 2013 | 06:06 PM
Chaver's Avatar
Default 90 Volvo 240 231 fault Code
Hello All
Starting to get a SEL after a 10+ miles drive. I checked the codes and found a 231 code. Which is fuel mix to lean to rich at cruise. I have cleaned the Mass Air flow Sensor and throttle body. I have used a whole can of Brake cleaner to check for vacuum leaks. I’ve replaced the O2 sensor. Would any one out there have any suggestions for me, Thanks.
Old Aug 1, 2013 | 06:12 PM
air leaks in the intake path between the MAF and the engine would be the big one. wrong fuel pressure (too high or too low). things like that.
ct60flyer
Sep 15, 2023 06:41 AM
goya
Apr 17, 2012 03:39 PM
MarkInTexas
May 26, 2009 05:28 PM
rekkab89
Apr 12, 2009 09:20 PM
wesweem
Sep 3, 2008 09:35 PM
