91 240 backup lite don't lit
Old Mar 7, 2006 | 10:05 PM
mktmkt's Avatar
Default 91 240 backup lite don't lit
The 240 backup lite all of a sudden don't lit. Check the bulbs, both looks ok. The fuze is also ok. What should I look for. Thanks.
Old Mar 7, 2006 | 10:08 PM
Default RE: 91 240 backup lite don't lit
There is a neutral safety switch under the plastic shifter cover inspect that.
The contacts usually get burnt over time and stop working.
If that is it you will need to replace it.
There is 2 phillips screws by it. The you should see a little tab going into a brown peice.
whp
Oct 13, 2013 07:50 PM
c note
Oct 25, 2011 10:29 AM
Typhoon
Jul 11, 2010 10:18 AM
shmoo235
Sep 29, 2009 08:11 PM
bobh1959
Jun 6, 2007 03:21 PM
