91 240 sedan Taillight wiring
91 240 sedan. I replaced both rear taillight assembly's. The drivers side works flawlessly. I was having some trouble still with the passenger side due to corrosion on the white connector piece.
I decided to cut off the white connector and hard wire the lights on the passenger side. Now the only ones that work are the turn signal and one brake light.
My question is how exactly is this supposed to be wired? Right now every socket has a ground and a positive. Does it matter which side is which? The lower right socket (works for break, not for run) is white and has 3 prongs. I have 1 ground, 1 to the other bottom socket and the run wire, and 1 to break. Is this correct?
My reverse light may be bad because of the bulb. It is milky white. Is it supposed to be that way?
Any help is greatly appreciated. Thanks.
There are never any cars like mine at junk yards in my area. Even if I found another car, the white plastic connector would most likely be corroded also.
This is apparently a very common issue with these cars. I was hoping someone could help me figure which wires go where.
on the right (passenger) side..
from behind, the light fixture looks like...
A B C
D E F
E is the parking light, and is a brown-white wire.
A is the brake light, and is yellow wire.
B is the reverse light, and is a black wire.
C is the turn signal, and is a blue wire.
Thanks Pierce.
On mine
If A B C
D E F
A is the fog light
B is reverse
C is turn signal
D is the driving light (on w/headlights)
E is empty no socket
F is driving and brake
Are D and F supposed to be wired together?
D is a white socket that has 3 prongs. All others have 2.
B is a 5w socket. All others are 21w.
Is B the correct position for the 5w socket?
On mine
If A B C
D E F
A is the fog light
B is reverse
C is turn signal
our 240 was a 1987, and has moved to oregon with my daughter-in-college. I only know what the 1991 wiring diagram says, as detailed above.
the right side fog lamp is not wired or populated on US models.
how could F be driving and brake, yet have a 2-pin ? a dual mode light would be a 3-pin.
yeah, I guess.
me, I don't like the idea of soldering that all down... those tail light assemblies should be replaced every 5-10 years depending on sun exposure and weather. I'd be more inclined to clean all the connections (soft clean pencil eraser works great on electrical contacts without removing the plating), and use some deoxit d100 on them.
ivrylineslead
Sep 15, 2006 08:45 AM
