91 240 - Strange clicking- Valves?
Old Sep 7, 2008 | 12:57 AM
sia's Avatar
sia
Default 91 240 - Strange clicking- Valves?
I have a 91 240 with 180k and it runs great but there is a clicking sound that is bothering me. I can hear the valves clicking away (but not too loud )and I want to have them adjusted just in case but there is also a strange clicking/clacking from inside the engine only when I accelerate. It is not a consistent clicking like the clicking of the valves. The clicking is very irregular as it comes and goes while I'm pressing the pedal. Again, it only happens when I accelerate but not on mild acceleration (probably around 2000rpm). I appreciate any help or direction. Thanks.
Old Sep 7, 2008 | 02:47 PM
tedv's Avatar
Default RE: 91 240 - Strange clicking- Valves?
Well, this goes along with your other problem, oil is not getting to where it should to lubricate, so the engine is already damaged. Your noise sound like a rod knock which is the death rattle of motors. Sorry!
Old Sep 7, 2008 | 03:21 PM
sia's Avatar
sia
Could it be possible that if the oil pump o-ring is worn that the pump is moving around a bit and causing this intermittent rattling sound? Thanks for your help.
Old Sep 7, 2008 | 04:30 PM
Or the rubber cushions between the lifter and valves might be bad.
Old Sep 7, 2008 | 04:40 PM
sia's Avatar
sia
Tech-
Is this something I could replace by just removing the valve cover? is it a fairly easy procedure or should I take it in?
Old Sep 7, 2008 | 04:42 PM
You would have to remove the timing belt and camshaft to replace them.
Old Sep 7, 2008 | 04:57 PM
sia's Avatar
sia
Ok, thanks. That will be another thing I'll look into besides adjusting the valves and having the oil pump looked at. Thanks again
Old Sep 8, 2008 | 02:38 AM
sia's Avatar
sia
well, I just got back from a long drive and it seems that I was wrong about the sound happening at around 2000rpm. The rpm and the engine speed don't affect anything since the rattling sound only happens when I accelerate and it is not very loud. As a matter of fact most people can't hear it until I point it out. I was driving on the highway and the rpms were at around 3000+ and there was no rattling, only on acceleration. The weird thing is that it happens when I press the pedal pretty far down when I want to get on the highway or pass somebody or even getting off the light.
Any other ideas what this could be?
Old Sep 9, 2008 | 11:35 AM
fredbyte's Avatar
I had a strange clicking on my 740. Couldn't isolate it. Then I noticed the waterpump was leaking. When I replaced the waterpump, the clicking went away!
To see how to replace the waterpump, go to www.stepbystepvolvo.com.
Old Sep 9, 2008 | 09:51 PM
sia's Avatar
sia
Thanks. I'll look around the pump. Although I have inspected the car many times and I have seen no leaks but I'll check around the water pump and see. Thanks again!
Old Sep 10, 2008 | 09:57 AM
mtsumedi's Avatar
Sounds like detonation to me. Fill up with 93 octane on your next fill up and see if it still does it. If it stops, do you next fill up with 89 octane and see if it comes back. If it doesn't come back then start filling with 89.
Old Sep 10, 2008 | 10:08 AM
sia's Avatar
sia
Ah. I like how you think. That sounds like something very possible in my case. I always fill up with 89. I have noticed that it doesn't always do it, but it does most of the time, specially when it's hot out. And sometimes sounds louder than others, so what you are telling me is definitely possible.
I was waiting for my tank to drop to about 1/2 and put in some acetone. I was thinking about adding about 3 oz on the 1/2 tank. I have read that not only does the acetone clean better than fuel injector cleaner but that it also raises octane. I was thinking about adding some xylene/xylol also. Thanks!
Old Sep 29, 2008 | 12:46 PM
sia's Avatar
sia
mtsumedi, you are a genius!
I decided to fill up with 91 octane last night (can't find 93 around here) but I still had about a quarter tank left with 87 in it. Well, I go to work this morning crossing my fingers 'cause I could always hear the clicking the loudest as I get on the highway on my way to work and guess what... no clicking at all. I even had the pedal pressed all the way and nothing. I tried all the way to work accelerating hard whenever I could and nothing. On my way back home for lunch (right now) I tried again and I heard it only once at the last hard acceleration try but I could barely hear it this time and I'm guessing my true octane rating is a little below 91 since I had some 87 left in the tank when I filled up. Anyways, just wanted to follow up and let you know the problem is fixed.... now on to my low oil pressure problem....
Old Oct 21, 2008 | 01:36 PM
mtsumedi's Avatar
ORIGINAL: sia
Thanks for the update. I was wondering what was going on with your situation.
You may need to retard the timing in order to run 87 octane and not have the detonation. It's up to you though because it will be a slight loss of power.
slsnumber1
Jun 2, 2012 08:02 AM
slsnumber1
May 28, 2012 12:08 PM
jprovinc
Aug 29, 2009 10:38 PM
itsagirl
Jan 29, 2006 06:36 PM
blase
May 2, 2005 01:20 AM
