91 740 bogs down when i go to accelerate
Old Aug 27, 2013 | 09:48 PM
devilsattic's Avatar
Default 91 740 bogs down when i go to accelerate
im new to this site and i have tryed several things like new plugs wires and cap rotor and air temp sensor.
but still no fix to the problem.
ive been told could be dirty air control valve or a clogged cat but im not sure going to try the air control valve please need help thanks
Old Aug 27, 2013 | 10:41 PM
the idle air controller is only invoked at idle, with your foot completely off the gas.
bogging down when accelerating could be from air leaks in the intake path, or it could be from weak fuel delivery. or it could be something completely different, hard to say.
is this 1991 a Bosch or Regina car? does it show any OBD diagnostic codes? (you don't need any scan tools to read the OBD codes on a 1989-1995 Volvo, just follow these instructions: Engine and OBD Diagnostic Codes and do "DTM #1" which is reading the codes. there's two sets of codes, jumper on pin 2 for fuel injection, and pin 6 for ignition controller.
Old Aug 28, 2013 | 11:47 PM
Titan Joe's Avatar
Fuel pressure regulator, temp sensor and lifter pump in the tank are suspects. The type of fuel injection makes a difference though. Codes are your friends too, so +1 to Pierce's suggestion.
Old Aug 29, 2013 | 10:28 AM
sicnarf's Avatar
A clogged fuelfilter?
maryafrench
Jan 10, 2012 09:53 PM
saperry
Apr 20, 2011 01:33 PM
dnarby
Jun 27, 2010 06:59 AM
wizkrz
Sep 4, 2008 05:15 PM
profp
Jun 4, 2008 07:59 AM
