'91 740 Front Camshaft Seal Leaking, Next to timing belt
Old Jun 30, 2006 | 10:13 PM
Clueless Scott's Avatar
Default '91 740 Front Camshaft Seal Leaking, Next to timing belt
How do I repair the front camshaft seal? Is it hard to do?
Old Jul 1, 2006 | 10:39 AM
Default RE: '91 740 Front Camshaft Seal Leaking, Next to timing belt
It is a fairly easy job to do.
Make sure you do the timing belt at the same time to.
Also make sure you inspect the tensioner pulley as well.
Replace all 3 seals at the same time.
Should take you a couple of hours to get it done.
rmc2010
Dec 5, 2016 11:05 PM
Joey Calabrese
Mar 18, 2014 09:19 PM
woodenyouknowit
Feb 20, 2012 10:08 PM
JHudson
Jun 21, 2010 04:04 PM
johnhon
Jan 6, 2009 10:02 PM
