91 740 stalls whil stopping and turning
Old Jan 30, 2005 | 11:09 PM
Matts volvo's Avatar
Default 91 740 stalls whil stopping and turning
91 740 stalls while stopping and turning, 160K Regina.
New:
High pressure pump in tank fuel pump
sock filter
inline filter
fuel pressure regulator
plugs
rotor
distributor cap
plug wires.
Brake booster
air cleaner
Have cleaned throtle body
fixed vacume leaks
Checked and tigthtened ground straps
switched relays fan aux with radio supp
some times (not often hard start when cold) but the stall takes place cold or hot. Enging always restarts in one to 4 tries ..So maybe I will go back to owning BMWs I could at least get them running HELP!!
Old Jan 31, 2005 | 01:23 AM
Default RE: 91 740 stalls whil stopping and turning
Have you checked the engine speed sensor that goes into the back of the engine where the engine and trans meets?If the outside sheilding is cracked at all replace the sensor that will make it stall.Have you also checked the power stage.It is mounted on the inside of the drivers side fender.It is black and mounted to an aliminum plate.
Old Feb 2, 2005 | 10:07 PM
Thx for the info. We are still working on it. Now it wont start at all. No spark from the coil.
Matts Volvo
Old Feb 2, 2005 | 11:30 PM
Check the things I suggested they will cause it to not start at all either.
Old Feb 3, 2005 | 10:01 PM
I bought a used coil--I know regina coils seldom go bad but it felt like a coil to me. IT was.
Thanks for your input. Its fixed --
Matts Volvo
Old Feb 3, 2005 | 11:55 PM
Im glad you figured it out.Regina's are very picky and a pain in the butt to fix.
alinux
May 14, 2012 01:49 PM
rainman14624
Sep 20, 2010 09:22 PM
big-guy
Sep 25, 2009 07:11 PM
Lxtasy
Aug 13, 2007 11:22 AM
hcbuzzmor
Dec 11, 2005 02:00 PM
