Problem when turbo to kick in
Old Jan 29, 2005 | 09:00 PM
jc740T's Avatar
Default Problem when turbo to kick in
I have a 92 740 t. Recently, when I accelerate enough for the turbo to kick in it feels like there is some type of pressure drop, and I hear a whinning coming from the front right side. I cannot get turbo boost. Any ideas where to look? I thought hoses, but cant find anything that looks cracked etc... Thanks.
Old Jan 29, 2005 | 09:28 PM
Default RE: Problem when turbo to kick in
Check the hoses and if they are really soft they might be collapsing.If you can have some one sit in the car with the emergancy brake on and holding foot on the brake.Have them hold the gas and slowly push down on till the turbo kicks in and watch the hoses and see if they collapse.Make sure you stand off to side so it the car moves it doesn't hit you!!!!
Old Feb 5, 2005 | 05:03 PM
jc740T's Avatar
I believe you are correct about the hoses, although they all seem soft. I just replaced the hose that goes from the maf to the airbox since it had a small hole, but that did not solve the problem. I then took your advice frin first post and it appears the hose from the intercooler (driver side) to the ???, and then hose from the ??? to the manifold are both really bad. The one to the intercooler is colapsing though. Can you tell me what each of these is called and where to get them cheap? Also, there is a pipe (???) in between each hose, what is that? Much appreciated. John
Old Feb 5, 2005 | 08:37 PM
If you have another car just take them off and take them with you.You can try an auto parts store that specializes in imports.There is one from the throttle body the the intercooler well actually 2 they have the pipe in the middle.Im not sure there exact name but any auto parts store should have pictures of the hoses.The other set of hoses is from the intercooler to the turbo.
Old Feb 6, 2005 | 06:37 PM
jc740T's Avatar
Thanks. In order to get the hose from the intercooler do I need to take off the radiator?
Old Feb 6, 2005 | 09:00 PM
No you don't just follow the hose and loosen the clamp.
tom0317
Jun 23, 2009 08:44 AM
tom0317
Apr 28, 2009 07:42 AM
rp850
Oct 22, 2006 03:34 AM
gwoodall
Jul 7, 2006 03:49 PM
kracunas
Mar 17, 2006 08:46 PM
