91 Volvo 240 Charging Problem. Voltage low when loaded
Old Aug 29, 2009 | 10:06 PM
Srogers's Avatar
Default 91 Volvo 240 Charging Problem. Voltage low when loaded
So I have a new battery and a new alternator (this is the second one). The Voltage is 14.00 when there is no load on it. However when I turn on the lights and voltage drops to 12.56. And when I turn off the lights the voltage will go back up to 14. Now all the grounds look good, and the wires look good as well. Im stumped at this point. And ideas???
Old Aug 30, 2009 | 07:53 PM
TURBO 245's Avatar
Check your ground from alternator to the engine block.I've seen the wire almost broke into,with maybe one or two strands holding it in the connector.If it checks out ok, read this post https://volvoforums.com/forum/volvo-240-740-940-12/charging-system-problem-totally-perplexed-33784/
If that checks out ok,I would remove the alternator and have it load tested.
Dan
Old Sep 1, 2009 | 09:49 PM
Srogers's Avatar
Originally Posted by TURBO 245
Check your ground from alternator to the engine block.I've seen the wire almost broke into,with maybe one or two strands holding it in the connector.If it checks out ok, read this post https://volvoforums.com/forum/showthread.php?t=33784
Dan
All the wires look good. I was talking to a few guys at work, and they all think that it is the fact that I got a remaned alternator, even though this is the second one. They all said never buy a reman one.
Old Sep 2, 2009 | 10:05 AM
fcpgroton's Avatar
Former Sponsor
Some auto parts stores can test your alternator in the car. I know AutoZone does. Take your car to them and see if the alternator is still good.
Old Sep 3, 2009 | 05:15 PM
fredbyte's Avatar
Sounds like the regulator part of the alternator.
shoreacres29
Feb 29, 2012 11:17 AM
Meateater
Jul 8, 2011 11:12 PM
CTBlack06Evo
Apr 16, 2011 07:04 AM
mcslexus
Apr 17, 2010 05:47 PM
volvo40_2k
Jul 28, 2009 09:18 PM
