92 240 Volvo AC part 2
Old Apr 24, 2011 | 05:01 PM
92_240_sedan's Avatar
Default 92 240 Volvo AC part 2
So after i had the system converted been driving for about 2 days and the AC works....sorta. I would say its running at about 50% capacity. My next issue is whenever i turn the car off after the AC has been running there is a hissing noise from under the hood that last about 10-20 seconds then stops. Is this normal or the old AC system developing leaks?
Old Apr 24, 2011 | 07:05 PM
jagtoes's Avatar
I don't suppose you know what the gage reading were after the system was converted? If so then just put a set of AC gages back on the car and see what the readings are. Also sometime the hissing can be water/condensation from the AC lines hitting the exhaust system or just internal system pressure. I would check the system with gages and go from there.
Old Apr 25, 2011 | 09:51 PM
ed7's Avatar
ed7
The hissing is the high pressure side and low pressure side equalizing.
Ed
memphis
Oct 25, 2016 09:01 AM
Ryan Baker
Apr 19, 2015 12:03 AM
Kiss4aFrog
Nov 20, 2013 11:19 PM
sillygily
Jan 12, 2013 02:05 PM
92_240_sedan
Apr 30, 2011 11:04 AM
