93 240 Overdrive Problem
Old Sep 11, 2010 | 03:32 PM
shyfive93's Avatar
Default 93 240 Overdrive Problem
my 240 wont go into overdrive. the electronic overdrive fuse keeps popping everytime i put a new one in. i need some help as to what i should do next. thanks,
93 245
Old Sep 12, 2010 | 12:04 AM
swiftjustice44's Avatar
Well, you have a short. The simplest place to look is under the car. On the driver's side of the transmission is a vertical solenoid near the shifter linkage. There is a single wire coming out of the top. Follow it forward and see if you can find an obvious break.
Old Sep 14, 2010 | 11:28 PM
shyfive93's Avatar
i cant seem to find a break. what do you know about iPD's overdrive solenoid bypass? im thinking about just doing that. after all, this is my girlfriends car and she doesn't ever use the overdrive button anyway.
thanks,
93 245
Old Sep 14, 2010 | 11:36 PM
I've never used one although they're simple to install. You can actually mod the existing solenoid to work like the IPD unit. Again, I've never done it but you can search right here on the sight for it. I've been fortunate in always being able to fix 'em.
lilsilver85
Aug 29, 2014 04:07 AM
doctorc
Mar 12, 2011 05:27 PM
pewterdude
Nov 6, 2010 10:24 PM
AnEskimo
Apr 5, 2010 09:58 PM
atllsam
Jan 25, 2008 08:25 PM
