93 240 wagon airbag srs problem
Old Aug 3, 2016 | 06:07 PM
prestonblack3's Avatar
Default 93 240 wagon airbag srs problem
I bought a 93 240 that wasn't running. Finally got it running after it had no spark and no fuel.
The problem now is the srs light. While I was trying to make sure all the connectors were clean after a failed attempt at resetting the light, code 1, I unplugged the 4 pin connector off the module under the seat. Turns out I pulled the plug off the wrong way, and the wires came out of the plug. I can't find any info on what spots these wires go into.
The module I pulled it off is a Bosch 0 285 100 016. 4 pin plug.
I have an 88 wagon totaled that I am ready to swap steering wheels with, but I live in mass and don't know about the legality of that matter.
Any help appreciated, I'm going nuts.
Old Aug 3, 2016 | 06:27 PM
Well I got the plug back in and it didn't blow up on me. Any diagrams on the wiring for this? I checked the plug behind the steering wheel and the one near the trans hub, both are clean. Look new in fact.
Old Aug 3, 2016 | 06:53 PM
Smith Volvo's Avatar
Banned
You should be able to pull codes from your OBDI plug - no?
Old Aug 3, 2016 | 07:11 PM
The codes read 111. In both ports. There is no srs code on the obd
Old Aug 3, 2016 | 07:57 PM
Cleaned terminals on both boxes under drivers seat, tried to reset light. Still on. Fault reading code 1
Old Aug 3, 2016 | 08:18 PM
Banned
I'll check the factory manual tomorrow for you at work and see what it says
Old Aug 3, 2016 | 08:36 PM
thank you.
Old Aug 3, 2016 | 09:35 PM
my next step is to check the charging system. making sure that the alternator is working and charging the battery. many posts seem to say to check the voltage, that a low voltage will cause the light to come on.
atlantadriver
Apr 26, 2021 08:25 PM
gordon368
Feb 7, 2017 02:56 AM
mavman
Mar 12, 2007 09:02 PM
mingster
May 2, 2006 11:08 PM
OverTheTop
Sep 29, 2005 01:04 AM
