'93 940 wagon 4 cyl auto --- poor acceleration
Old May 19, 2006 | 09:13 PM
pisque's Avatar
Default '93 940 wagon 4 cyl auto --- poor acceleration
Hello everyone,
Sometimes when I accelerate from a stop, the car feels sluggish, as though there is no power at all until I get to about 10 mph and then it's fine again. This happens about once a week or even less. Also my check engine light is on, however, I'm unable to get the self diagnostic unit to work. I do know how to use it as I've done it several times before. Has anyone had this problem ?
Old May 19, 2006 | 09:19 PM
Default RE: '93 940 wagon 4 cyl auto --- poor acceleration
When was it last tuned up?
When was the last time the throttle body was cleaned?
What happens when you try to pull codes?
Old May 19, 2006 | 09:53 PM
pisque's Avatar
I had a major tune up about 10k mile ago and had the throttle body and the idle air control valve cleaned at the same time which is about 8 months ago.
I get 2-3-2 in position 2 and 1-4-3 in position 6 but the problem is that I cannot delete these codes. I have deleted the 2-3-2 code before this problem with the acceleration but now it doesn't work.
Old May 19, 2006 | 10:16 PM
The knock sensor might be totally shorted out or the wire might be. That would not allow you to clear the code.
Check the wiring.(biodegradable wiring)
Also check at the main plug at the firewall.
Old May 19, 2006 | 11:31 PM
pisque's Avatar
I will check on that in the morning.
Thank you very much for your help.
mcintorb
Oct 2, 2015 09:34 PM
Rekhati
Jul 27, 2010 10:31 PM
redbottle
Jul 18, 2010 09:26 PM
becketts
Feb 18, 2010 11:35 PM
pisque
Aug 21, 2005 09:52 AM
