T5 1998 S70 misses in Cyl 4 during high acceleration
Old Feb 18, 2010 | 03:50 PM
becketts's Avatar
Default T5 1998 S70 misses in Cyl 4 during high acceleration
Have a question to a problem that evades a resolution.
1998 S70 T5 uses only one coil for all cylinders.
During high excelleration cylinder #4 misses ever so briefly between 3-4 gear and 4-5 gear. Causes engine light to come on. Error specifically states it is cylinder 4. I have reset the engine light and can cause the miss to occur again. At no other times will Cylinder number 4 fail to fire.
Any ideas what might be causing this?
Thank you
Old Feb 18, 2010 | 10:32 PM
Last Full tune up?
Old Feb 18, 2010 | 11:35 PM
gdog's Avatar
+1 to what Tech said.
Like you said, you've got an issue with cyl 4; what I would do is:
  1. Pull the plugs; compare plug from #4 to the others; does it look different?
  2. Ck compression on all cyls; is number 4 low compared to the others?
  3. If above looks OK, then I would focus on ignition specifically; could be a bad plug wire (replace the whole set, OEM) and/or bad cap or rotor. If it's due, just replace all this (part of major tune up).
  4. Beyond that it could be a faulty injector on that one cyl; less likely than above though.
Let us know what you find.. good luck.
Straussie0611
Jun 12, 2013 10:11 PM
stanb
Jun 26, 2010 08:35 PM
Hugh G Rection
Jun 24, 2009 12:59 PM
BorninBflo
Jun 30, 2008 10:58 AM
pconfar
Dec 10, 2007 06:11 AM
