'94 940 front seats
Old Apr 28, 2011 | 02:36 AM
Oregonite's Avatar
Default '94 940 front seats
Will other year and model front seats interchange with '94 940? If so, what years and models. Will I have problems with the plug in for the power seat?
Old Apr 28, 2011 | 08:55 AM
swiftjustice44's Avatar
As long as they are power...any 940 seat will work.
Old Apr 28, 2011 | 05:41 PM
lev's Avatar
lev
Non power will work fine too... Just like late 1990-92 740 will be OK too, for the 940. Earlier years have to be mildly modified.
Old Apr 29, 2011 | 08:45 PM
Oregonite's Avatar
Default 850 or 960 front seats in a 940?
I was wondering if anyone knew if power seats from a 850 or 960 sedan would fit in a '94 940 sedan with power seats?
Old Apr 30, 2011 | 08:10 PM
lev's Avatar
lev
850, no. 960, yes.
Old May 1, 2011 | 09:35 PM
will s90/v90(960-II, eg 1995+) seats fit a 91/92 740/940 ?
my 92 740 has manual (non-power) seats, so I realize I'd need to hack up a power harness for this (I'd likely try and get the connector ends from the donor car), I'm an electronics geek so I'm pretty sure I can manage this.
Old May 1, 2011 | 10:35 PM
lev's Avatar
lev
It's easy. Plug the positive lead into the fuse box, the negative under the console...
Old May 1, 2011 | 11:15 PM
well, the memory seats from a late model car will require the memory controller, which I believe is under the carpet near the airbag controller, but yeah basically. power and ground. probably should be switched power so they can't activate when the ignition is off, and it probably should be a circuit that has sufficient power to handle the stall load from seat motors, which is a fair amount (15 or 20A, I bet?)
actually, come to think of it, I'd rather the seats were UNswitched power, so you can adjust them before getting in the car. my wife runs the seat so far forward I can barely squeeze in behind the wheel
Old May 2, 2011 | 09:12 PM
lev's Avatar
lev
Nah, the memory is in the seat... And, yes, unswitched power is what I have, I just used one of the fuses in the boxes, forget which one, but it is the one that later carries the seat power in the 940s... I did put a 940 power seat in '92 740... works great!
sunliteinn
Sep 2, 2013 10:05 PM
HECTORPORTALUPPI
Mar 25, 2012 03:08 AM
olgol
Jun 9, 2010 12:58 PM
olgol
Jun 9, 2010 11:40 AM
tomservo
Interior
May 1, 2008 05:31 PM
