94 940 no power to Voltage regulator
Old Jan 19, 2022 | 11:03 AM
  #21
You should be able to follow the red D+ wire back through connector C51 terminal 4 and connector C2 terminal 22 (from earlier diagram) to find the open circuit between the D+ wire on the alternator and the bulb.
Old Jan 19, 2022 | 11:18 AM
  #22
Stellar's Avatar
Ok see if i can figure it out. Admit I'm not good diagnosing electrical. thanks for your help & patience.
Old Jan 19, 2022 | 02:13 PM
  #23
silvermine's Avatar
think you're on the right diagnostic track Stellar, but one thing i don't understand is... you made a jumper between the battery and alternator D+ connector, started engine, connected jumper
and alternator began charging as it should. you then said you disconnected the jumper (with engine still running?) and alternator was no longer charging. if that's the case i believe that shouldn't happen.
the alternator should continue to charge until the engine is shut off.
this link also gives some insight into a jumper wire
https://www.volvoclub.org.uk/faq/Ele...torNotCharging
Old Jan 19, 2022 | 03:59 PM
  #24
Stellar's Avatar
Are these right ones?
Old Jan 19, 2022 | 04:47 PM
  #25
silvermine's Avatar
goodness .. i wouldn't even touch those.... those do seem to be the connections in hoonk's posted diagram though.
Old Jan 20, 2022 | 11:09 AM
  #26
Stellar's Avatar
Default THANKS silvermine for getting me to this article & author ? of article
Source
Old Jan 21, 2022 | 06:52 PM
  #27
Stellar's Avatar
Default Thanks Everybody
Originally Posted by Stellar
Back on the Road. I learned alot about charging system THANKS Everybody
Volvo940epa
Mar 17, 2021 06:23 AM
mschultz373
Oct 4, 2020 12:22 AM
jdpuyear
Nov 11, 2012 01:22 AM
trek786
Jul 11, 2010 08:07 PM
turbo940v
May 2, 2010 12:32 PM
