94 940 No start when hot
Old May 12, 2010 | 09:01 PM
94 940 500k or bust's Avatar
Default 94 940 No start when hot
Starts great when cold, will die at prolonged idle, and will not start when hot.
Code is 2-2-1. MAF and Throttle body cleaned. New cap, rotor, wires and plugs.
What next? Fuel Pressure regulator or Temperature sensor?
Old May 18, 2010 | 09:42 PM
tedv's Avatar
That, and try cleaning the Idle Control Valve...
Old May 20, 2010 | 10:10 AM
Default Eureka!
Hard start due to weak fuel pump. Original lasted 446,500 miles. Also, had a frayed RPM sensor wire and a cracked distributor cap. Took the opportunity for a tune up. Running Great! If you have intermittent loss of RPM (needle flops to 0 and back) and occasional flop at cruise, check your RPM sensor wire. $65 part, $80 labor.
Old May 20, 2010 | 08:16 PM
tedv's Avatar
$80 labor for the rpm sensor? Ouch!
84minieldo
Jan 4, 2015 08:43 PM
94 940 500k or bust
May 12, 2010 09:04 PM
beardo265
Sep 27, 2007 09:24 AM
pisque
Aug 18, 2006 08:33 PM
