940 code question
Old Jan 27, 2009 | 03:50 PM
mikkowus's Avatar
Default 940 code question
I own a 1994 940 wagon and recently the check engine light came on. I noticed that I was getting 16 mpg so I pulled codes.
I picked up codes 113 and 212 on the A2 port. As I understand it these indicate a bad oxygen sensor. However, I also picked up code 122 from the B3 port. I cant seem to find anyplace that lists this code and what it means. Any ideas?
And something else... When popped the hood, I noticed that the oil stick was pushed up and there was oil all over everything. Over the summer I checked the flame guard and it was clean. what else cold cause this to happen?
Old Jan 27, 2009 | 04:56 PM
mikkowus's Avatar
Default RE: 940 code question
I did a little more research and apparently there is a lot more that can be cleaned out besides the flame trap. Hopeully that will solve the problem.
Old Jan 27, 2009 | 05:14 PM
TIPSP's Avatar
Got Boost?
Could be your crankcase ventilation system?
I believe that Code 122 is air temp sensor.
Old Feb 2, 2009 | 09:50 PM
mikkowus's Avatar
Thanks, I'll check it out.
91shelby
Feb 4, 2011 08:24 PM
Elsid
Sep 9, 2010 08:42 AM
badmonkey
Jul 28, 2008 09:15 PM
gzh
Mar 21, 2007 09:29 PM
aarp guy
Mar 26, 2006 10:29 AM
