940 engine interrupts after start
Old Feb 13, 2022 | 02:56 PM
Wojtek123's Avatar
Default 940 engine interrupts after start
Hello, i've got some issues with my 940 with B230FD engine (1996).
Engine, after starts end when i press the gas pedal, interrupts and work like on this video: https://streamable.com/au91d3
I replace lambda sond, check intake system and everything looks fine. Is it possible, that this issue came from broken MAF?
Old Feb 13, 2022 | 05:39 PM
lev's Avatar
lev
Yes, a bad MAFS is certainly a possibility. Any OBD codes? It'd be better if the OBD confirmed a bad MAFS.
Old Feb 14, 2022 | 02:21 AM
Wojtek123's Avatar
Unfortunetly, there is no OBD errors.
When the engine runs for a while, the problem goes away. I will try to find the MAF and replace it for verification.
Old Feb 14, 2022 | 09:08 AM
silvermine's Avatar
before replacing stuff check the easy ... i had a similar condition due to moisture and corrosion buildup inside the distributor cap.
Old Feb 14, 2022 | 10:17 AM
lev's Avatar
lev
Problems disappearing once engine is warmed up is unusual in my experience with MAFS. Also, MAFS will normally trigger OBD codes. I assume all your ignition parts, plugs, wires, rotor, coil, are in good shape? Also, moisture, yes, that too is a possibility.
Old Feb 17, 2022 | 03:11 PM
Wojtek123's Avatar
I've checked distributor cap. There is some corrosion,
I cleaned the contacts with sandpaper, but still, black scorch marks remained. I've replace with brand new distributor cap, sometimes after start and fast press gas pedal, engine speed drops very slowly, but not interrupts. I'll be watching, but for now, i think, the problem is solved.
Türk
Jan 24, 2017 01:54 PM
gibbogti
Nov 18, 2015 12:41 PM
dhammika
Jul 20, 2015 10:23 AM
KSIMP88
Dec 23, 2006 08:23 PM
thevipergts
Oct 1, 2006 10:05 AM
