940 headlight probelm
Old Aug 30, 2009 | 01:15 PM
Ashokan1's Avatar
Default 940 headlight probelm
1992 940 GL - No power to the headlight on the drivers side with the dash headlight indicator light on. I'm thinking maybe the relay for the indicator is bad. Is that relay on the fuse panel and, if so, which relay is it?
Thanks.
Old Aug 30, 2009 | 07:04 PM
TURBO 245's Avatar
Is low beam and high beam both out?Bulb failure light on?If yes to both these questions,relay is probably bad.
To access relays, remove the snap-on cover over the cigarette lighter, then remove the two screws securing the storage box. Remove the box and you will see the relay tray behind the fuses.
Dan
Old Aug 31, 2009 | 07:05 PM
Ashokan1's Avatar
Yes to both. I'll try to get a relay this week.
Thanks.
Old Sep 7, 2009 | 05:32 PM
Ashokan1's Avatar
Actually I was able to solve the problem without a new relay. Seems the female connection on the relay board was where the problem lie. It was overheated and the plastic slightly melted into the connector creating a situation where the male pin was not making good contact to the metal on the female connector. I meticulously cut away the plastic and was able to slightly crimp the female connector to create a better fit. All's working now and I did manage to get a spare relay from a friend. Thanks.
Old Dec 1, 2009 | 08:10 PM
Ashokan1's Avatar
My headlight problem has resurfaced. Worked fine since September when I refurbished the connector in the multi-connector. I haven't looked in the dash yet but I'm wondering if I can simply splice the two wires and eliminate that circuit from the multi-connector?
Volvish
Jan 17, 2014 11:30 AM
Peter1234
Nov 23, 2010 01:19 PM
Volvo940
Dec 11, 2007 11:09 AM
dhansen
Nov 27, 2006 09:44 PM
banani
Sep 21, 2005 10:19 PM
