940 High Idle-3500 RPM in Park
I have a 1992 940. It has driven for years with no issues. A few weeks ago the idle started running up to 3500 RPMs in park and neutral. The engine runs a normal idle in reverse, drive, low 1 and low 2. However, it runs rough in drive, backfires etc . . .
I have changed the throttle control valve, calibrated the throttle position sensor, replaced the crankshaft position sensor, and replaced the cold start injector. Problem not solved.
Has anyone else seen this before?
Engine Codes are as follows:
Bank 'A' Socket 2 = 321, 221, 121
Bank 'A' Socket 6 = 111
Bank 'B' Socket 3 = 122
Thanks in advance,
The Sweedish Wrench
Thanks in advance,
![Confused](https://volvoforums.com/forum/images/smilies/confused.gif)
