940 Hit by snow plow.
Old Mar 8, 2013 | 09:19 PM
92_240_sedan's Avatar
Default 940 Hit by snow plow.
My 940 was hit by a reversing snow plow and smashed the driver side headlight assembly.
I had still been driving it with the broken light because i am a delivery driver. Tonight when i went to turn my remaining headlight on my dash lights dimmed and smoke started coming out of the dash. Then my horn started to blow all on its own. I figured the dangling light was shorting on something so i took it off and all seemed well for a hour then it started doing it again when i turned the lights on. Now even with the lights off the second i turn the key the horn sounds.
The insurance company is most likely going to total this car because of the fender damage but i cannot afford to get another car so i was just going to buy it back from the insurance company.
PLEASE tell me there is not any terminal damage....
Old Mar 8, 2013 | 09:40 PM
analogies's Avatar
Default smokie cluster
Junk yard parts....
door: $ 45 dollars
relays: $2 to 16 dollars depending on what the one you need
gauge cluster: $28 dollars here in California with two exchanges if they don't work
check your relays:
the drawings pertain to a 94 I think...but might be the same general location and definitely need to dig in under the hood and fender area to see burnt or cut wires...under dash as well.
Attached Thumbnails 940 Hit by snow plow.-940-2.jpg   940 Hit by snow plow.-940-relay-diagram.jpg
itsazoo
Dec 23, 2009 09:15 AM
kapka42
Dec 21, 2009 09:47 PM
Chris13700
Nov 29, 2007 06:25 PM
740man24
Jul 29, 2006 09:37 PM
