940 no diagnostics
940 no diagnostics
hi everyone been looking at forums becuase ive got theobd port and have tried to read any faults cus car wont run properly splutters and dies after start up cant touch throttle will cut out wen it is warm sputters wen trying to pull off getting dangerous now so any way this car is a 95 23se turbo tried 2 obd scanners no nothin and another thing never had any sort of ceck light come up supposedly the srs red light which does come on so is in there theres power at obd plug is there a scanner out there that is compatable or will work any ideas welcome
The following 2 users liked this post by lev:
digital.mick (02-24-2023),
Ty Jessop (03-21-2021)
there's no ODBC-II plug on a 940, ODBC-II was introduced in 1996. all 940's have a primitive Onboard diagnostic port with a jumper wire and a LED and button, thats all the code reader you need. put the jumper wire in pin 2 to read EFI codes and pin 6 to read ignition codes. press the button for 2 seconds, release it, and count the pattern of blinks. 1-1-1 means no code. if you do get a code, press it for another 2 seconds, and see if you get a different code, repeat until the first code is shown again.
your symptoms could be ignition problems, fuel injection problems, air manifold leaks, most anything.
various trouble shooting guides here, https://www.volvoclub.org.uk/faq/Eng...eSymptoms.html
no bud obd socket in center consul and voltage there car starts every time cant touch throttle first quarter of pressure on accellerater farts splutters cuts out runs and dosnt splutter as much but lots hesitation first quarter of throttle exuaust seems sooty iac works when clamped tps clicks but is it working wish i had the bleeper box under bonnet but no seems this year was the swap over year need to know if there is a reader that will work
well thouhgt it was but mite be wrong its a 23 se turbo estate 940 august 95 its just typical thats when scrapped the little black box and went obd socket from wot i can gather its in the center console between two front seats im thinking it mite be diferent software or smmut because its early modle mk2 the tps clicks iac worked wen clamped pipe air mas made it worse wen unplugged so probly works seems to run for around 10 seconds before stopping from cold when u do get it warmed up cuts out when stopping first quarter of throttle will sputter then other times will shoot off then like just die off noticed that summtimes dipping clutch seems to bring it back on the throttle rpm senser on bell housing would of been easy if odb worked thaks bud
is this a world market car or USA ? 1995 was the last model year for US 940's, and by august, they'd started making model year 1996 850's and 960s, there was no US model 1995 940SE (other than a 1991 940SE which was really a 960 with the b230ft turbo)
the LH2.4 fuel injection control unit, and the EZ116K ignition control module simply did not have the logic or CPU power in them to create ODBC-II codes.
I'm having a really hard time understanding your streamed together misspelled and unpunctuated statements, it makes my head hurt to try.
as far as your symptoms go, those could be, as I said, caused by air leaks in the intake pair path (basically anywhere between the MAF and the head, cracked plastic airpipe bellows, cracked idle air controller hoses, etc), or it could be ignition system problems (bad/old coil, distributor cap+rotor+dust shield, or spark plugs, spark plug wires)), it could be insufficient or too much fuel pressure (weak fuel pumps, clogged fuel filter, bad fuel pressure regulator). or it could be something entirely different.
yeh sorry pierce am not that computer literate writing never been great either any how bud first reg in 1 8 95 not us b230 fk vehcle id yv1945811t1164819 for gb market had problem for 18 months now and is really getting undrivable any help apreciated probly end up ringing t j stone to come and fetch it big scrap yard in the sky haha cheers peirce
The self diagnostics port for a b230 fk euro right hand drive car is shown in the parts diagram. It's #29 and mounted between the strut tower and the firewall under the hood. The next step will be learning how to read it if you don't have the old volvo scan tool. You can learn how to retrieve, and interpret those codes on this page https://www.matthewsvolvosite.com/read-codes-volvo-850/
had a look at throttle set up the throttle wheel is sitting in its stop position but looked at throttle lever and its seems to have the screw turned all the way in looked at the haynes and that says it shoulb be only a turn or so after setting the lever to its stop possion this screw is rite up levell wiv its locking nut gona back it off tmoz and see wot happens and about obd11 car reg on 1 8 95 so it is classed as 96 and should work like every one elses starting to think plug coulb be faulty specialy wen some guys snap on couldnt cnnect and that was 4 grand so wernt cheap but other two were cheap would the tps still work with that throttle possion screw all the way up? thanks again bud
trucknut324
02-16-2021 11:46 PM
dickwroe
03-27-2006 09:41 PM
