940 overdrive does not work
Old Nov 20, 2008 | 09:54 AM
fpa's Avatar
fpa
Default 940 overdrive does not work
I just bought a 1995 940. It runs well, but the switch on the automatic transmission shifter does not work, so the car runs at 4000 rpm at 70mph. I know nothing about how the car should run. Does that switch enable a 4th gear ? What should I do to get this fixed ? thanks for your help.
Old Nov 20, 2008 | 10:44 AM
Default RE: 940 overdrive does not work
If you press the button does an arrow come up on the dash?
The setup will always have overdrive active unless you press the switch and the arrow is on.
Old Nov 20, 2008 | 02:31 PM
fpa's Avatar
fpa
The arrow is ALWAYS on. Pressing the button does not turn the arrow off. And there is no overdrive as a result, I guess.
i am new to this forum. Thank you so much for your help.
Regards,
FPA
Old Nov 20, 2008 | 02:36 PM
TIPSP's Avatar
Got Boost?
Then your overdrive mode is always on, henceyour 3rd gear is the max right now.
You should fix that or you will have to fill up your tank A Lot.
Old Nov 20, 2008 | 02:40 PM
TIPSP's Avatar
Got Boost?
Maybe the relay is bad, or maybe the switch is broke?
Check here for everything you need: http://www.ipdusa.com/Volvo-940960/Transmission-&-Drive-Train/Automatic-Transmission/c-1-136-278-676/
If you will rarely push the button when it works, you can always get the OD bypass switch which makes it like a standerd 4 speed trans, but you will not be able to use the button anymore: http://www.ipdusa.com/Volvo-940960/Transmission-&-Drive-Train/Automatic-Transmission/Automatic-Over-Drive-Solenoid-Bypass-Kit/p-136-278-676-1031/
Click Here for relay locations.
Old Nov 20, 2008 | 03:46 PM
Start by checking the relay.
jelarf
Jan 27, 2021 03:43 PM
lilsilver85
Aug 29, 2014 04:07 AM
smellycat
Nov 27, 2012 06:20 PM
Ruskya Mafia
Jan 24, 2010 08:55 PM
mtidwell
May 2, 2006 09:15 PM
