940 Overdrive Solenoid
Old Jul 6, 2009 | 10:37 AM
Big Al MA's Avatar
Default 940 Overdrive Solenoid
How difficult is it to replace the overdrive solenoid on a 940, what's involved? I am a solid mechanic, but I don't want to get over my head with the tranny. I change my own fluid but that's it for trannys and me, at least up to this point... Any input?
Old Jul 6, 2009 | 10:33 PM
lleroyb's Avatar
Default Which transmission do you have?
Try doing a search for "Overdrive Solenoid" and see what pops up.
Old Jul 7, 2009 | 06:42 AM
Big Al MA's Avatar
I did some digging and decided to go with the bypass kit from ipd. I'll post an update when I've completed the work.
Old Jul 9, 2009 | 03:34 PM
tomarocca's Avatar
Thumbs up
Simple; located on the left side high on the trans;
Held on with 2 12MM bolts. Angle is tight; and may need a
bent 12MM wrench.
Test the relay; by removing the cover; and manually clicking
the magnetic lever.
Before you pull it; test it first with a 12V+ direct lead.
Before you re-assemble; blow out the air passages.
If your solenoid unit is dead; remove the plunger; and it
will be full time overdrive.
Good luck. And use jack stands for safety
lovingthis240
Feb 8, 2012 07:26 AM
tnburban
Jun 8, 2010 11:32 PM
Fresheadies
Jan 16, 2010 01:31 PM
jktiffin
Jun 15, 2006 11:17 AM
smetshouse
Dec 1, 2005 01:21 AM
