940 Rough Idle
Old Mar 17, 2008 | 11:14 PM
randy's Avatar
Default 940 Rough Idle
It seems as though whenever the weather goes from cold to warm and humid (which happens frequently in the midwest), my 95 940 (non-turbo) wagonmisses and loses power until it is completely warmed up. I've had the car since it was new and I have not noticed this before. It was serviced and tuned up 3000 miles ago. Any ideas?
Old Mar 18, 2008 | 07:40 AM
gforce's Avatar
Default RE: 940 Rough Idle
Randy, You might try cleaning your IAC (idle air control). Look on this thread page for daver80 post on "where is isle air control" I he posted a pick on location. He has a 240, I have a740, same on our cars not sure on 940. Cllick on the resource thread at the top of this page and go down to forums click on Brickboard and search idle air control. They have lots of info. and instructions. Hope this helps you get her running smmmmmooooth.
Old Mar 19, 2008 | 09:22 PM
funnyguy44444's Avatar
I would definitely start by cleaning and lubricating the idle air motor using some carb or brake cleaner and then some wd-40. That should help. If it doesn't fix your problem it is probably the mass air flow meter which unfourtionately is quite expensive to replace.
Old Mar 21, 2008 | 02:53 PM
randy's Avatar
Thanks gforce and funnyguy44444! I plan to go check those ideas out as soon as the weather breaks
nkinkade
Feb 28, 2014 08:49 PM
rosesforlily
Nov 5, 2009 09:23 AM
yank50
Mar 14, 2009 11:15 AM
joker834
Jan 19, 2009 05:06 PM
