940 SE Instrument cluster (does not conform)
Old Jul 2, 2012 | 02:16 AM
Shel1555's Avatar
Default 940 SE Instrument cluster (does not conform)
Tonight on a whim I decided to pull my gauge cluster to see if I could fix my on/off speedo problem. It's removal does not conform to any of the tutorials I found, as there are two little plastic cover clips in the roof of the bezel, upon removal reveal two simple phillips screws, which I removed. The bezel though, is quite stuck, it's started to come down from the top, but it's quite long and covers up the AC vents, I'm afraid to yank on it anymore for fear of breaking it... any hints??? Edit: Maybe it's cuz it's a 960 in disguise... will look at those.
Old Jul 2, 2012 | 02:37 AM
Shel1555's Avatar
That would explain it, it's got a 960 dash.
Old Jul 2, 2012 | 09:02 AM
indeed, the 940SE is actually a 960 turbo-4. it was a transition model, filled the niche of the 760 turbo.
the 960's (and later 760s) have significantly different innards... the dashboard, and dash wiring harnesses, and relay and fuse panels, etc etc are completely different than the 740/940. they also have more chassis sound proofing.
Old Jul 2, 2012 | 02:30 PM
lev's Avatar
lev
Just follow instructions for a 960 instrument panel removal...
The bezel has phillips screws inside the vents, at least two if memory serves... They are up there, have to point the vents fully up to see them, the upper left and one or two on the extreme right. Then there are clips so it takes some prying to pull the bezel out.
Old Jul 2, 2012 | 05:27 PM
Shel1555's Avatar
Seems there's no way around first pulling the radio and lower trim piece/ pieces, then removing the upper one. I'm not going to reveal exactly why, but I just bought a replacement upper trim panel off eBay... 40$ shipping inc...
Old Jul 2, 2012 | 10:00 PM
lev's Avatar
lev
Ts, ts, someone got a little impatient?! That bezel is a little trying, quite different than the 740/940. I also hate the middle console of the SE/760/960. It never seems to go back on easily, with the heated seats switches, etc. on the way.
Old Jul 2, 2012 | 11:03 PM
Shel1555's Avatar
I just hope my speedo works when I'm done
SB245
Jun 6, 2023 01:50 AM
scrumblero
Oct 27, 2014 12:08 PM
marceys60
Sep 20, 2013 03:19 PM
dom2248
Mar 4, 2013 10:40 AM
volvo5volvo
May 29, 2012 05:46 AM
