940 shifter issue
Old May 30, 2023 | 05:06 PM
Tnfiddler's Avatar
Default 940 shifter issue
I have a 93 940 sedan. I just had the car to a shop to replace the shift lever. The old one was dry rotted and disintegrating. The mechanic said I needed a shifter assembly. The car will shift into another gear without depressing the button on the lever. Example- it could accidentally get pushed up into reverse while driving down the road. Anyone have experience with this?
Old May 31, 2023 | 08:43 PM
Moetheshmoe's Avatar
If it feels sloppy then it's probably a cheap, little bushing that keeps it in alignment. I have a '93 and it wore out. So I replaced it with this - https://www.fcpeuro.com/products/vvo...ns-mtc-1220141 and it works smooth now.
Old May 31, 2023 | 08:44 PM
Actually this is the one - https://www.fcpeuro.com/products/vol...c-trans-381704
Old May 31, 2023 | 08:47 PM
IPD has them too -
https://www.ipdusa.com/products/5881...-666143-106486
Old May 31, 2023 | 08:49 PM
Here's an old post about shifter problems -
https://volvoforums.com/forum/volvo-...-2-1-a-101360/
Old May 31, 2023 | 08:52 PM
Tnfiddler's Avatar
I got more clarification from my mechanic. There is a plastic piece broke in the shift assembly that acts as an interlock. I'm afraid it's going to be hard to find unless I find a used one
Old Jun 1, 2023 | 10:43 AM
was the mechanic referring to the button in the shift handle that broke? (that button actuates the interlock release)... If so, I'd start by going to a dealer web store to view the parts diagram and find the volvo part number then search eBay and Amazon (assuming the dealer site shows the part as discontinued).
Old Jun 1, 2023 | 11:07 AM
Tnfiddler's Avatar
No, not that button. It's a plastic piece that the cable goes thru. Probably have to find another shift assembly
Old Jun 1, 2023 | 12:22 PM
do you see the part on this diagram to get a part number?
https://parts.volvocarsofsantamonica.../GR-70728.html
As to finding used parts you can search yards to see who may have a 940 via car-part.com or try a Volvo specialist like Erie Vo Vo. You can also try ebay or craigslist to see who's parting a 940...
micahmorgan1010
Oct 28, 2019 10:58 PM
920940
Jun 25, 2016 02:12 PM
jsmilde
Feb 10, 2014 05:19 PM
Rath
Jun 30, 2010 11:03 PM
pillow
Apr 4, 2008 04:06 PM
