940 temp gauge sensor wire question please help
My 940 temp sensor for the temp gauge the one above the knock sensor..
can anyone please tell me if the solid yellow wire is on the top or bottom when I plug it back in to the sensor, I usually take a photo so I wouldn't forget. I unplugged it to clean it and the resin crumbled and the wires are a little loose so I'm going to hat shrink the nd if the connection and hope that will keep them intact.
so does the yellow solid color go in on top pin or bottom bullet pin
ASAP I'm trying to get it done thank u
I thought the temp sensor for the dashboard gauge was one pin (or am I confusing this with my Mercedes, hah!) ? the one for the engine management is 4 pin,
anyways, these sensors are temperature sensitive resistors, they aren't polarized, so it actually doesn't matter which way its connected.
Thank you for the photo
Thank you, that's what I thought that the yellow one is under the striped one, got it and it's working now, thank God, now if I could just get to my egr valve.
Anyone looking for a vacation to Florida?
I have plenty of space, I'm on Big Lake Harris..close to many things, Disney, Springs, Space coast.
Need someone to help me remove my egr and the black oil separator box, it easy to get to I just can't get the bolt off the egr..
Thanks so much for the photo, it helped...
These may help
Sneak an extension drive with a flex or wobble end on it to remove the 12 mm bolts, then move the wiring harness out of the way.
Unplug the EGR from the top of the box, it just pulls up. IAC hose is disconnected in the previous picture.
Once that's done, gently rock the oil separator back and forth until it comes up. Don't break the splash tab off the right side of it.
jupoloopo
07-29-2014 09:13 AM
