940 timing belt tension spring lost
Old Mar 27, 2008 | 07:03 PM
turbo940's Avatar
Default 940 timing belt tension spring lost
Ok so i lost the spring that pushes out the tensioner on the timing belt. I know the tensioner is crucial but what can i do about the spring, i looked everywhere and cant find it.
for now i just used muscle power to push it as far a possible and tightened the nut to where it wont nudge anywhere.. at all
The tension seems the same as it did with the spring in.. Will i be ok without it?
big arrow denotes spring small one denotes direction it pushes
Old Mar 28, 2008 | 09:11 AM
billofdurham's Avatar
Default RE: 940 timing belt tension spring lost
It is not a good idea to omit a part on the timing belt.
The spring is listed as a separate unit on VADIS. Check with a dealer.
Old Mar 31, 2008 | 04:35 PM
daver80's Avatar
Turbo- My common answer- any way you could dig one out of a 940 in a junkyard? Dave
IanMitch
Oct 2, 2015 06:18 AM
FredRydr
Oct 15, 2011 03:08 PM
brennanpersonal
Jan 2, 2009 09:17 AM
Fuh_Q
May 25, 2008 02:34 AM
