S80 Drive belt: Need to release tension
Old Jan 2, 2009 | 07:44 AM
brennanpersonal's Avatar
Default S80 Drive belt: Need to release tension
HI:
I want to replace a failed PS pump on this vehicle. No one seems to have laid out the exact procedure for loosining the drive belt. It could be beyond my ability, but maybe not.
Thanks,
Mike
Old Jan 2, 2009 | 08:07 AM
Default RE: S80 Drive belt: Need to release tension
Does the serp. belt tensioner pulley have a cover on it hiding the nut?
Old Jan 2, 2009 | 08:33 AM
The pully surface is exposed with a nut protruding. It appears to be about a 14mm.
Old Jan 2, 2009 | 08:48 AM
You can use a long wrench on there to release the tension on the belt.
Old Jan 2, 2009 | 08:49 AM
...there is no cover on the pulley.
Old Jan 2, 2009 | 08:51 AM
I guess I knew that, but here is my concern.
If i put a socket on the bolt and pull to the front or push to the rear-what happens?
Does just turning the nut release the pully tension and that's it and just reverse it to retighten?
Old Jan 2, 2009 | 08:52 AM
Use the head of the bolt to turn the tensioner and release the tension.
Old Jan 2, 2009 | 09:00 AM
Left or right, and then what happens? Does it justmove out as if on a worm gear?
mike
Old Jan 2, 2009 | 09:15 AM
You pull it towards the front of the car. The tensioner swivels and takes tension off the belt. You pull it towards the front of the car then slide the belt off. Then release the tension till you go back on.
Old Jan 2, 2009 | 09:17 AM
Thank you very much. I will give that a try.
Mike
Mr diy
Nov 23, 2014 04:43 AM
guest01
Nov 5, 2011 10:11 PM
volvoQ's
Nov 18, 2010 09:11 PM
henning
Oct 31, 2009 10:49 AM
turbo940
Mar 31, 2008 04:35 PM
