940 turbo, oil leak
Old Nov 27, 2006 | 06:21 PM
DJboozeAlot's Avatar
Default 940 turbo, oil leak
my 1991 940 turbo has an oil leak, as you can see in the picture below:
i tried to tighten up the nuts in the picture, but they seemed tight already. i was wondering if there is an o-ring in there, maybe that is bad. just want to know before i start pulling things apart and running around looking for parts
Old Nov 27, 2006 | 08:57 PM
Default RE: 940 turbo, oil leak
Looks kind of like the o-rings between the cooler and the engine might be leaking.
You would have to remove the cooler to replace. By removing the 2 lines then the Bolt setup holding it to the block.
Is there any oil above the filter assembly?
92_240_sedan
Oct 20, 2013 08:06 PM
pburchins
Aug 27, 2010 08:20 PM
ROBLU540
Feb 20, 2009 07:59 PM
witstaffy
Jul 25, 2005 09:31 PM
GaryBrad
Jun 13, 2005 12:10 AM
