940 turbo stalls when hot.
Old Jul 23, 2016 | 12:48 PM
zs1's Avatar
zs1
Default 940 turbo stalls when hot.
My 98 2.3 turbo 940 runs fast (1500 + rpm) when started cold, then stalls at junctions when hot . I have replaced the fuel pump relay and air mass meter. Makes no difference.
The fuel pump relay (both old and new) gets very hot to touch. The 2 relays in the first row of relays (on left side of rack) behind fuses under radio also get very hot.
When hot if I unplug the air mass meter the engine idles fine untill the car stops and is started again.
Help please, any ideas would be great.
Old Jul 23, 2016 | 03:57 PM
lev's Avatar
lev
Well, how hot is hot, vs warm? That shouldn't make your idle high, anyway, hot or not.
Idle control valve? Good place to start.
Air leak after the MAFS? If too much air comes in, computer sends corresponding fuel, etc.
Old Jul 23, 2016 | 04:24 PM
zs1's Avatar
zs1
Will check out idle control valve and air leaks. Will get back once i have checked. Thanks
Suzyq
Jul 7, 2018 04:53 PM
84minieldo
Jan 4, 2015 08:43 PM
Stefan Neculai
Jun 9, 2012 05:41 AM
rainman14624
Sep 20, 2010 09:22 PM
beardo265
Sep 27, 2007 09:24 AM
