940 turbo,... td04 or te05
which would be a better turbo for my 940, i get good power bottom end but drops off, i would like to have constant power, power when i get on the interstate i have the stock td04 and its boosted to 15lbs i dont need more bottom end power just top end.. i have access to a te05 but if its not a power increase there really no point.. which one should i go with?
Te05 is bigger that a td04. So it will give you more boost at the top end, but will take a little longer to spool up. So you'll loose a little bottom end. My car has a TD05. I have no complaints about spool up time. I can't really say anything for the TE05. You may try the Turbo Bricks forum. They may know a bit more about that.
8V Performance Camshafts
Turbo Performance Camshaft
There's two options. I'm not sure about the differences. I've never tried them, but I've looked.
xcellusa
09-08-2011 12:00 PM
