AC blowing fuse
Old Jul 14, 2016 | 10:33 PM
Cwazywazy's Avatar
Default AC blowing fuse
Ever since I washed my engine bay a couple days ago my AC has been blowing the 8a fuse. If I pop a new one in it's fine for a minute, then it blows and my AC shuts off. Obviously some wire is shorting, but where to check?
Old Jul 15, 2016 | 02:45 PM
Nichals's Avatar
check fuse 3 for the heater fan, part of the same circuit but thats the one that delivers most of the punch. Clean them up with a wire brush and put some dielectric grease on the contact points.
Old Jul 15, 2016 | 02:47 PM
Nichals's Avatar
also did you spray in your engine bay? there could very well be a short somewhere that the sitting water is connecting.
Old Jul 16, 2016 | 12:42 AM
Cwazywazy's Avatar
Yup, found the short. Biodegradable wiring strikes again, part of the AC clutch wire lost its insulation and was shorting on a bracket or something it was ziptied to. Moved it forward a bit to a good section of wire and tightened the ziptie, no more problems.
kcpaz
Apr 11, 2009 01:18 PM
jdv999
Jun 3, 2008 05:37 PM
tbenner
Feb 20, 2008 11:09 AM
macdogd
Dec 25, 2007 09:27 PM
mrchuck85
Feb 28, 2007 09:08 PM
