advice
Old Sep 24, 2020 | 04:42 PM
bigarms24's Avatar
Default advice
on the way to the gym yesterday I went down the 5 degree little decline to the entrance of the gym and my 88 240 dl cut power and died i stopped put in in park fired right back up and didnt die again what would of caused it to die it was running great and then when i left it was running great again i did change the fuel pump and filter the one on the frame last year
Old Sep 25, 2020 | 07:17 AM
Goldenblock's Avatar
Default Advice
intank fuel pribably bad. Or low gas at thst time????
Old Sep 25, 2020 | 07:18 AM
Default Advice
Intank pump bad or low gas at time of occurrence!!
Goldenblock 2 million miles
Old Sep 25, 2020 | 07:57 PM
bigarms24's Avatar
it has 3/4 tank of gas if not closer to a full tank. it so far only happened once but i am not sure when the in take fuel pump was changed last but why would it start right up if it was a fuel issue
Old Sep 25, 2020 | 08:05 PM
Default Pump
If its a huge incline or decline... It could possibly move fuel away momentarily from pick up temporarily reducing fuel pressure. Is your main fuel pump aftermarket???
I have a Rare regina 2 pump system and my intank pump does nothing to effect fuel pressure or performance!
Old Sep 25, 2020 | 11:17 PM
on my 740 turbo bosch 2-pump system, when the in tank pump went out, below 1/3rd tank, the engine would starve under heavy acceleration in a mid gear and mid to upper RPMs, also the main pump was quite noisy even with a full tank. new tank pump, main pump went back to silent.
Old Sep 26, 2020 | 02:00 PM
bigarms24's Avatar
when i replaced it i went with a factory pump on the frame that i got through volvo of Palo alto its maybe a 5 degree decline
lowdown89
May 5, 2012 03:49 AM
tommydavis
Jun 15, 2011 07:32 PM
rumbel
Aug 25, 2009 06:47 AM
dman777
Apr 27, 2009 01:42 AM
mikeheraly
May 28, 2008 04:38 PM
